Inertia
That $20 stethoscope you could picked up last week, would probably have given you conclusive evidence, insteada ALL of us wearing out our crystal ball . .
Amazon is on the wayThat $20 stethoscope you could picked up last week, would probably have given you conclusive evidence, insteada ALL of us wearing out our crystal ball . .
There's other builders that offer crates, Blueprint does offer a milder 375 hp 408, even if you do somewhat mild hop ups to 360 you'll be around there. What is your rear end ? if 7 1/2 not strong enough any V8.As much as I would love a 408, I would be looking for a similar LA360. Highly doubt my 904 trans, rear end and suspension could handle a 408. Unless I am wrong....
I actually have had a few that never had issues. I am not easy on parts.There's other builders that offer crates, Blueprint does offer a milder 375 hp 408, even if you do somewhat mild hop ups to 360 you'll be around there. What is your rear end ? if 7 1/2 not strong enough any V8.
Could not pinpoint where the noise is coming from with the stethoscope. Placed it on the valve cover, heads, oil pan, bellhousing, etc. and did not hear the obvious ticking/knocking.
Yes, and still could not pinpoint.Did you unscrew the needle tip, and use the remaining "trumpet" end to get direction ? Then put trumpet on v/covers etc .
