The 128 rule is a constant and for SBC only. All other engines the constant is different. He doesn’t have a constant for LS. What he used wasn’t right and he knew that. There’s nothing wrong with the math, it just hasn’t been corrected and proven yet. It’s going to take 100’s of cams and pulls to do that.
He just used what he had.
He is a research engineer and near the end of his tenure. I spent my career as an engineer devising tests and pulling data out of them to learn. The older I get I would rather have the knowledge than the win. I still say he knew the answer and saw 3 cams that were right and used this test as a learning tool and let the next generation win and build their reputations, he just wanted a larger data set. You can actually maybe get that vibe from him if you watch his last few videos on the test. Pure conjecture based on someone who has a similar career (different field though)
