340 is just too many cubes... no idea why people get greedyALso a 340 under the hood now.
The stock HP single system is pretty quiet inside.I believe it's actually a resonator and no muffler.. i'm too lazy to go look though
Mine got louder when I went with a full 2.5” system vs my previous 2-2.25” exhaust. Same mufflers.I wonder if anyone has done a study on decibels of loudness between the different size exhaust using the same mufflers for the given size so you could get apples to apples comparison. That could also be a deciding factor for some of us older folks that don't like too much noise anymore but still like power.
You need to search and watch David Vizard Powertec 10 videos. One is about zero loss street legal exhaust. Another delves into equal length headers.I thought a street engine needed some back pressure to keep lo rpm exhaust velocity up for low speed power?
Isn't that why street driven engines benefit from a small cfm carb and why the factory reduced the tail pipes
to 1 7/8" from 2 1/4"? This wouldn't apply for an open header race engine at 6000 rpm.
....but the question is how much power might be lost going from 2 1/4" to 2" exhaust? I'm wondering if there
may even be an improvement below 3500 rpm?
Don't you still have his wagon, Tom?273, this chart above was from testing on Dad's car long ag. Pretty easy to see. We made a single system so we could really see what mufflers did or didn't do.
I've always run 2 1/2" with manifolds or headers (street cars). I just received my TTI 2 1/2 system for my 340 Swinger. When I look at the size of the pipes (except where they smashed it to fit around the starter) I can't believe this wouldn't be more than adequate for any small block up to 6000rpm.2.25" minimum. I always run 2.5" on my street 340's.
Now you're getting into facts. Why would you let facts get in the way of a good story?i wonder how often most guys drive their cars past 4000 rpm?
90 mph with 3.23 gears and a 26.5" tire is only 3685 rpm.
90 mph with 3.55 gears and a 27" tire is 3976 rpm.
Calvin Elston explains how he views the mass of exhaust gas leaving the cylinder.maintaining flow away from the exhaust port in the low to mid range is going to bring the most gains. If we can do this without stuffing up the top, even better.
Makes no sense. At least no sense without context. What's the pressure in the intake? Where was the pressure in the exhaust measured? Are they measured on the same scale? Modern cars use absolute pressure. Atmosmopheric pressure is 14.7 psia. 1 psia is very low pressure.i think this thread is finally dead so i'll just throw this out there. The last info i read (that was way over my head) said at lo rpm 1lb. back pressure kept the cylinder filling, overlap and scavenging events uniform.
I can hear those murmurs!
