pacuda59
pacuda59
Did Chrysler make a 7.25 rear end in a BBP?
I was talking with someone yesterday at Carlisle that claimed they did.
I don't know the particulars, I just know Chrysler made um. Also as luck would have it, you cannot make a LBP 7 1/4 from a SBP 7 1/4 as the housings axles and backing plates between the two are all different. I know. Stupid.
A body 7-1/4 was big bolt pattern 73 and up only if it was a disc brake car.
All A body 8-1/4's were big bolt pattern.
F,M,J used 7-1/4 and 8-1/4, all large bolt pattern. More F bodies had 7-1/4's than 8-1/4's.
F rears are wider than A's.
So it looks like I'm limited to Darts and Dusters if the F,M and J's are wider.
What are these worth?
