Double post …. Move along… move along….
Not according to Rat B! According to him, you know nothing & are WRONG!The LRE came with a special 727 and converter.
The 1969 Six Pacs had the same as the Hemi 2600 RPMI found this in my files. Probably picked it up from FABO........Lol like most things!
I did exactly that on a turbo 350, a week later the trans was toastI always thought it was funny as hell the Chevy guys that put Vega converters behind their hot small blocks and even big blocks thinkin they were the hot ticket. I personally have seen the results layin in a steaming pile of metal and trans fluid on the street. lol
Anyone?I have a 340/727 behind my 71 Dart. With all the paperwork I got with the car nowhere does it say what stall is in it. Is there a way to find out without pulling the transmission? Everything was rebuilt a couple of years ago by the previous owner.
Anyone?
The only way to check it is to road test it. Think about it. If you have paperwork or a number on the unit that said it had X stall and X Flash stall would that mean that’s what it is? Or will it be whatever it is after testing? Your best bet is to take it out and test the brake stall and then flash stall then you’ll know exactly. The search function here or do a a DuckDuckGo search On how to test for bothAnyone?
The only way to test it correctly is if it has a manual valve body. If it does, put it in high gear. Set the parking brake, hold the brake pedal firmly. Now ease into the gas watching the tach. When the tach stops climbing, that's your stall speed. You can do it in first gear if it's not a manual valve body, but your result will not be accurate. I would suspect you could subtract at least 500 RPM from that result to be "close". But that's just a guess.Anyone?
My brother had a friend back in the '70's that owned a street/strip 350 powered '66 chevelle. It had one of those vega converters in it. The converter worked really well without issues.I did exactly that on a turbo 350, a week later the trans was toast
Now I know 2900 rpm stall certainly isn't 4500 rpm, but show me a 4500 rpm converter that has any kind of good street manners while running errands with Auntie Inez who keeps asking :Is this car broken?"
You can preach it till you're blue in the face and some people will be stuck in the 70s forever. They will just not listen. It'll be their loss.Have you ever driven a car with a modern 9.5" convertor in it from a place like dynamic or ultimate? You would be surprised as to how well they behave.
I don't know when the good performance converters became popular but the early ones were just like you described. I sold quite a few back then when I worked at the speed shop. Most were just smaller diameter converters for a higher stall. The converters now are way different by modifying them internally.I have a '70's era 9 inch converter in my 340 Duster. It feels quite mushy at low speeds. Stand on it,locks up and goes.
I had a Circle D converter in a late model Mustang. Cruising around town it felt stock but hit the gas pedal and it felt like you just added 50 horsepower. It dropped my ET half a second in the quarter mile.Have you ever driven a car with a modern 9.5" convertor in it from a place like dynamic or ultimate? You would be surprised as to how well they behave.
Those days are over…. If you want it to be.I have a '70's era 9 inch converter in my 340 Duster. It feels quite mushy at low speeds. Stand on it,locks up and goes.
Not over yet,my converter would be good for a bracket racer.Those days are over…. If you want it to be.
You’ll love the new offerings. Mines a 9.5 that drives normal until you hit the go pedal hard.
