aaronk785
I know my 383 RR converter stalled about 2800 behind a mostly stock 440. Made a big difference over the 11.75 low stall. They made low stall 10.75 converters to.
Right! Tell that to that ratty bastid. lolWhere can one purchase these random "stamps"?..But try installing a low stall in place of a high stall in a low geared truck...and be prepared to have your head snapped off..Having a trans that operates unsatisfactorily is an irritation; weather it be from a mismatched converter or improper shift points/firmness.
No, I get it. You're the one being totally ignorant. Carry on with your bad self. lolI made my point and you don’t get it. It’s 2022. What Chrysler did in 1970 means nothing. No one should ever use an 11.75 casein anything today. Get your head on straight and think for once.
Clear case of revisionism or if that’s the wrong term, redefining the past using today’s standards. And some off these post authors sure seem eerily familiar, like ghosts from the pastIf "what Chrysler did in 1970 means nothing", then no one should ever call a 340 a performance engine because it only made 275 hp. A lowly base model v6 makes more than that now. AFAIK, the factory hi stalls were all 10.75 units. None were 11.75. Sure, the stall on a factory HS converter may have not been very high. Even so, I would imagine the 340 cars would have been rather doggy on the bottom without it.
Ok. I see now. You're just a damned idiot.So let me get this straight. If today, you had the choice of a 10 inch 2800 converter and an 11.75 inch 2800 converter that Chrysler stamped “hi stall” on you’d take the latter? Go it. No one EVER beside Chrysler called a 2800 stall converter “hi stall” unless it was a magazine ad. You don’t get anything other that you have to defend your foolish myths. Ridiculous how old men hold on to myths to keep their memories relevant. Keep using junk. You love it.
A street high stall will be something like a 2400 to 2800.In a recent post Duster Daddy mentioned a Factory High Stall used on the 1974 Duster 360 can anyone give me any info on this? Also was there a high stall available for the 340 and if so what was the stall??
Skip
The problem here is your comparing today’s standards as well as your own vs yesteryears ratings. This does not make you right.I made my point and you don’t get it. It’s 2022. What Chrysler did in 1970 means nothing. No one should ever use an 11.75 casein anything today. Get your head on straight and think for once.
Well saidThe problem here is your comparing today’s standards as well as your own vs yesteryears ratings. This does not make you right.
Rustyratrod is correct. You are not.
However! If you want to compare yesteryears standards vs today’s standards, it is a totally different ball game. One we are not playing.
Surely your not that thick headed are you? No one here is comparing a 70's Mopar factory Hi-Stall to the 4500 stall convertor that Frank Lupo built for my 416 Barracuda. Stay on point here.2800 wasn’t a high stall in the 70’s either. Just because Chrysler stamped a term on something doesn’t make it so. For example anything over a stock cam and the converter was at best holding the engine back. If your definition of high stall is a factory 11.75 in converter you use the wrong definition.
I agree.2800 wasn’t a high stall in the 70’s either.
According to who? You? LMAO! Against your standard?Just because Chrysler stamped a term on something doesn’t make it so.
The key word in this sentence is “IF” which I never said in my direction that you (might have) assume(d).If your definition of high stall is a factory 11.75 in converter you use the wrong definition.
I don’t think no one would agree the better converter move, if so warranted by the build. But this is not the topic or argument here.So let me get this straight. If today, you had the choice of a 10 inch 2800 converter and an 11.75 inch 2800 converter that Chrysler stamped “hi stall” on you’d take the latter?
I know Bobby a little bit. This is not what he thinks or would or has done in the past on a performance build. He equipped the build as needed.Go it. No one EVER beside Chrysler called a 2800 stall converter “hi stall” unless it was a magazine ad. You don’t get anything other that you have to defend your foolish myths. Ridiculous how old men hold on to myths to keep their memories relevant. Keep using junk. You love it.
And your attempting to “Unwash the Masses” via this discussion that doesn’t apply to the thread topic at hand?
It’s funny how no one is arguing with you on today’s standards of what I high stall converter is and how much better the converters are of today but amazing how you stick to your tune on what the factory calls a high stall converter on there performance cars vs what they put out on regular cars.
Just freaking amazing….
