kris66cuda
What kind of fans are good for extra cooling power for my 360 what's a good setup for it
Thanks
Thanks
I have run this on every car i have ever owned. It is an amazing fan, and moves a ton of air at low speeds.
http://www.summitracing.com/parts/flx-418
Is this for a 66 Cuda? If so, and you are running the original radiator, you will be looking for the 2 piece metal shroud and special smaller 17" fan. The hot ticket for that setup is the 6 bladed fan with a clutch from a later car and eliminate the spacer. That's what I'm running in my 66!!
If you need a 17" 6 bladed fan, let me know, I have a couple extra!! Ill also include a pic of my setup when I'm at the big computer!! Geof
I stand corrected...thanks guys!! Geof
I used that style nylon mechanical fan for a couple of years.. It did not pull nearly enough air thru the radiator for my application.. Went to a Derale flex fan, with lots of blade pitch and the air flow is dramatically better. Motor runs at 180 on a 180 thermostat, rarely gets to 190 even in heavy traffic.
