Buford19
Can a person install the rear quarter glass, before felts? Is there a particular order that the glass and hardware have to follow to install? If so, what is the proper sequence to follow.
Still haven’t even started them. Ran into a few hick ups install the new engine. Now dealing with steering issues ,and power steering pump. Mopar power steering pump produces too much psi for my power rack. Still making headway on the project, taking longer then I would like.How did you go with them? I know how hard they are to do in the Charger. Still can't get them to line up properly either. Also I used the cat whisker type and not the windscreen wiper rubber type, makes a difference. Use silicon spray to finish off and lubricate it, just check if the window tint is OK with it if you have it.
