Sorry....been a long weekend.
I have been working on wiring....more like dragging it out. They hang for a few days so they straighten out.
In the mean times I need to remove a header...drag...plugs, column....etc to get at my starter and route the wires in an inconspicuous manner + my crappy T on the front brake line is still leaking....should of used galvanized tubing instead of stainless.
So I am starting on the console shifter mods as we deal with wires and in an effort to move forward I am also putting together the instrument cluster/bezel and all switches inside after hours.
So I got bored ans started working on the shifter as it all needs to go together anyway.......got the old shifter mount out and the new shifter mocked up at proper height. Noticed a few problems that have solutions...at least the one's I have encountered so far.
To get clearance without hacking your ratchet shifter in half you will have to hack your console indicating light housing in half.
But whats worse....anyway I am finalizing height and will be hacking the old mount down to proper specs to get it just under the console cover and keep it from hitting in front in P or at end of stroke in 1.
Stay tuned....I need new 4" wheels for my grinder.
Also a pic of a simple mod to bring detail into your interior.....simply polish your high beam switch.....It's chrome believe it or not.
3 more comming
Mop
