Alex5280
74' Duster
Looks great Bob!!!
Laquer thinner, but it evaporates quick. I think mineral spirits will cut that and it will stay wet longer so you can wrap a rag around it and let it soften a while for less work. Also less fumes inhaled, lol. If that gets most of it, you could then do a final cleanup with the laquer thinner.View attachment 1715014041 What's the solvent of choice to get butyl sealant off the back of the windshield stainless trim? Looks like someone put this stuff on with a shovel....
^ That is the bracket kit I got and successfully swapped over my slant 6 PS pump. Used the original slant 6 pulley too.
got it.
Nice! I had no frame of reference since this is what the old girl looked like when we brought her home and that was 5 years ago...
[Zillow: Real Estate, Apartments, Mortgages & Home Values]1715014589[/ATTACH]
It was a combo of green mold and the beginning of moss. The car sat outside nearly 10 years without a hood in the PO's back yard. She was a mess...Yikes!! I can't tell if that's moss or algea. You come a long way.
I'm going to make some sort of tank to soak the things, i think the lacquer will work better than mineral spiritsYou could make a pvc tube to soak the windshield trim in. Get a piece of 2 or 3" pvc that will accommodate the curve of the trim, and glue a cap on it. Stand it up, put the trim in it, and pour it full of cheap lacquer thinner from Home Depot. It will soften the goop up and it will about fall off. Hopefully, it won't eat the glue holding the cap on the bottom of the tube....lol. I use this trick to get good mirror glass out of Rallye mirrors I want or need to paint.
I'll look at the box when I get home Alex. I bought them about 4 years ago. They were inexpensive but I think they fit the billBob, Where did those sport mirrors come from? They look good!
