Ok so I figured out the 4 barrel air cleaner on the 74 A-body 360 had the rounded flair on the snorkel
I have the correct pie pan and lid and a snorkel that is too long, but it has the correct flared opening
So I'll need to cut the snorkel down to the proper length, then modify the opening in the pie pan to receive the shortened snorkel. I may get lucky and the shorter snorkel may just slip inside the opening instead of sliding over the tabs as it does now. Will not be utilizing the heat stove. The flap is removed and the opening where the stove connects to the snorkel will just allow more air in as will the two 2-1/2" holes I'll be drilling in the back of the pie pan that faces the dizzy
Going to show my 318 pride with one of these Astralian Penta-star 318 Four Barrel air cleaner decals. The guy at the company in Australia that sells these told me that the 318 was the only V8 4 barrel offered there back in the day.
