AlV
Crabs in a barrel
Bob it's time to install your exhaust manifolds.
I just received the hardware for them Al.Bob it's time to install your exhaust manifolds.
When TTI makes the headpipe tell them which manifolds you have and he'll put the flange on for you. I think I used an antisieze or a hi temp rtv where it goes through the water jacket.I just received the hardware for them Al.
What do you think I should use on the studs? Some guys say pipe dope, some say locktite. Going to have TTI make me the downpipes to the Jegs exhaust kit. Where can I get the flanges for the pipes to mate to the manifolds?
View attachment 1715024598 View attachment 1715024599
It was exact. Perfect.Never mind I just clicked back a page and found the answer.
How does it fit?
Will do. I guess I guessed wrong!Looks good. need to turn your fan around.
Well my ignorance has yielded knowledge! Turns out my fan was backwards and when turned right side out, it hit the other pulleys. I then found out from good old Al I need a fan spacer. Son of a gun...Me to on the country boy. it's all good.
This radiator fit perfectly in the factory mounting holes in the rad support. Didn't need to alter a thing. Excellent product!
I'm wondering what sealant to use on the radiator drain plugs and in the exhaust manifold studs. Also, just use the gasket on the thermostat housing or use a sealant with it?Glad to see it fit good. I think I'm going to order one myself. Glad I could help save you a few bucks.
Shawn, do you think I can borrow your primer shaft?
I figured out it's cheaper just to buy it!No problem, I can ship it to you. PM me you address.
Keep in mind you have to pull the distributor, and oil pump shaft out of your motor to use it, I can walk you thru how to do it.
Also you can buy them real cheap and have it forever.
manciniracing.com
Glad to see you back John. Thanks for the kind wordsI haven't posted on your thread in quite awhile but I have still been following the progress. - Things sure seem to be coming together nicely!
