No problem, glad I could help, just put some clear packaging tape over it.Will do. We got the timing tape yesterday. Thanks
I tried spraying clear coat over one once, and it just blurred the ink on the tape.
you need a Tuff Wheel adapter. moves the steering wheel outward a couple of inches
Dodge Plymouth Tuff Steering Wheel Adapter 3467186 New MoPar | eBay
D/D those things are a real pain. It does not look like it is snapping on the clips properly. I hope you have good clips?
I fabbed up an aluminum plate for the HEI module that is held in place by the rear coil bracket bolt. When I moved the module to be right next to the dizzy I checked the timing and it read 50* at idle!! Did not move the distributor at all since yesterday. So I set the initial to 18* and the motor runs GREAT!I had an issue with too long a wires on the hei module on my engine start stand.
Moved the hei module close to the distributor and problem solved.
