abodyjoe
just stating the facts man. i can't help it if you don't like it.
ok don't take any of this personal or as a shot . this is just what pope into my head when i saw the post.
personally i don't see why anyone would put a tube k-frame in just to run all stock suspension stuff. seriously what advantage is there? at the most maybe a couple pounds is all i can see.
where i see that you may run into problems is making it build-able from all stock suspension stuff to a full rack set up using the same frame itself. guess it could be done but i also think any weight savings if any in the first place will be thrown out the window having to put mounts for a rack,steering box, idler arm, strut rods..etc..etc..
good luck, hope it all works out for ya but its gonna be tough i think. i also think people will be very surprised as to how expensive it will be in reality after piecing it all together. hell a stock rebuild on a front suspension can get to $1500 real easy when doing everything and converting to large bolt disc (unless your getting a lot of free parts), add close to a thousand more for the new tube frame and your not far off from something like an alter-k which includes everything to drive in the garage with a stock suspension and drive out in a couple days with a coil over rack and pinion set up. only thing you need to supply is grease and brake fluid..
like i said man, good luck. keep us posted.
The thing I really want is to use the factory engineered torsion bar set up and have a light weight rack and a light weight K frame. There is a lot of weight to be saved by replacing the steering box with a rack and the K frame itself is heavy.
Have to disagree. A manual box is made of aluminum so very light. Take a hole saw to your K frame if you think it's heavy,lol...
That is one of my reasons for running a tube frame. SteveThank you replicaracer43 for your reply as I will probably be one of very few that agrees with you. I personally love the torsion bar suspension but I feel there is one more reason to want a tubular K frame and I would say to run any oil pan.
Well this is still going to be going here guys so I hope you all like what you see in a couple weeks when the prorotype is done.
Oh it wontCareful putting the rack on the front. I don't think you can push the tie rod ends out far enough to get back the lost ackerman (tire/wheel will get in the way). Ackerman is somewhat important if you want to turn. In a straight line its probably OK. I would love to see you succeed, but steering/suspension geometry shouldn't take a back seat to fitment.
Imagine a rack where the sway bar would have been.
looking forward to see it! And this is funny!!!!!!!!!!Gee..... I'm picturing it now. =P~ :toothy10: :snakeman:
Wylde1.
In front of the rackWhere will the sway bar be mounted?
I think it is kind of comical people are saying that the oem k-frame is heavy. To replace the thing to save a few pounds will be an expensive proposition, unless you are building an all out race car. I read somewhere that the total weight savings between an oem, non power steering car and an alter k is only 50-60 pounds. For the price of it, I would just as soon skip a few Big Macs. No doubt the car will steer better with a rack in it, but again, for a car that will get driven 5 miles to the local burger joint and back will you notice?
