chryslerfat
Being it is not a Formula do as you wish with it. The value wont change much and if I had a 4 speed in mine I would keep it. Makes it more of a a fun drive in my eyes.
This lesson is for you Vic.
American Motors = Twin-Grip
Buick.................= Positive Traction
Ford..................= Equa-Lock and Traction-Lok
MOPAR...............= Sure Grip
Oldsmobile...........= Anti-Spin
Pontiac...............= Safe-T-Track
Chevrolet............= Positraction
Your in the land of MOPAR now so out with the posi stuff.
Only 2 wires going to the coil, Tony, unless you have a tach!! Distributor to neg. and harness to positive. Looking good so far!! That grill center is not hard to find, and I believe its the same from Valiants, just the emblem is different. The emblem is the hard to find part, at least one in good shape. Keep up the good work!! GeofHey guys, I got a little work done on the cuda today and it is really close to starting it up. I haven't had a points unit for a while so help me refresh, the single wire from the distributor goes to the neg. side of the coil and the hot (key on) goes on the pos. side right? Isn't there suppose to be a wire coming from the starter relay also to the pos.side?
We also got some disassembly done like small blk did and we also found out I need front floors. Everything is still looking as good as I thought it would.
Fstfish66, I have the spitfires on my car, and I must be one of the lucky ones, as I bought mine early on and received them right away. They were only $188.00 back then, and the person who turned me on to them received one of the first sets. They told me that the ones they received needed some minor mods to fit in, but Harold supposedly changed them up a little, and mine went right in. All I had to do is turn the 90 degree filter adapter a little to make clearance to remove the filter. There was scant little clearance to tighten the pass through bolt back down, but I did it. I do have manual steering and an automatic though, and in Vic's case with the scattershield he may have some clearance issues that I did not encounter. I thought I read that you couldn't use them with a 4 speed, but that too may have changed. My muffler guy squacked about the clearance where they dump, but that was only to trump up the price a little. I'm pleased as punch with mine, they really woke up the little 273!!! Just a little insight from ol' cosgig!!! GeofHEADERS,,,,if you can avoid fender wells,,do so, we all had them once upon a time,,i did i saved the piece that was cut out,, and now have different headers and the piece is welded in,,the hole, if to big weakens the structure of those old A bodys,,
here are the options,, 1- custom made,,big bucks
2 hooker model 5208, small hole in lower fender well needed,available,,
3 TTI, headers,expensive
4 dougs headers, expensive,
5 spit fires, best bang for the buck,may have to wait for them
there are several topics on this board on this,,i think the spit fires are the best deal,,,no cutting of sheet metal,,but some other mild modifications needed,,,
and im nto to sure on this one,,,but i think it would work,,some one may know ?????? dodge dakota or ram truck 5.2 magnum exhaust manifiolds may fit,,if so they look nice,,and im sure flow better then any early manifold,,and cheap to buy and easy to find
i have a set here i bougth for my street rod,,,if some one needs measurements
Hell Fish, look at the one on the front of my car. That came from a 66 Valiant parts car I had as my car was hit in the front end when I got it. Only the emblem is different, but the holes are the same to mount them. Also, look at the one on MeMikes car, also the same. At one time I had 3 of them to choose from, so I painted one the correct flat black, one body color and the third I left primed just in case. In the end I chose to put the correct flat black on, I thought it looked the best. Sorry, Vic, that was 5-6 years ago and sold the extra ones with some extra grills I had for Valiant and Barracuda. I still contend that they are not that hard to find. If I come across one, you'll be the first to know!!! GeofPretty sure they are different, but can be made to work.
