mullinax95
as long as you have the correct rad for the water pump. your 360 has the aluminum wp that dumps on the pass side and a cast in timing marker on the drivers side. if you had it on the 273, then what you have should work. the original setup for your car would have a cast iron pump dumping on the driver side and the bolt on timing tab on the pass side.
that rad looks like it will work.
Aren't there two different water pumps?
One is considered late model while the other is early model. The one that is on the 360 in the picture does not have any timing marks whatsoever. So which pump do you think I have?
