Why is my post #13 a head scratcher? Pretty self explanatory. The 440 in the limited built 68 Dart was an RB motor as was the 440 in the '69 M codesNo doubt. Head scratchers for sure.
Sorry, I just hit the agree button. I was confused as to why you mentioned the 440's in the 69's because we were talking about when the 383's first cane out in the 67's.Why is my post #13 a head scratcher? Pretty self explanatory. The 440 in the limited built 68 Dart was an RB motor as was the 440 in the '69 M codes
Post # 10 got me thinking about the B/ RB blocks and since they mentioned the older built 383 required I was wondering why? Putting a B block 383 in a Barracuda couldn't be more taxing than the taller RB 440.Sorry, I just hit the agree button. I was confuses as to why you mentioned the 440's in the 69's because we were talking about when the 383's first cane out in the 67's.
Mine is a 67 383 convertible an ordered car with a build date of 4/19.@ZMan67S , when was your's built?
I thought the same thing when I read it. That's why I responded the way I did. No harm, no foul.Huh..... the Mod agrees with me.
I'll take that as a win.
According to VIN #'s, several 67' Barracuda 383 Formula 'S' cars were
built in the November production at Plymouth.
Until someone on the production line figured out that they could
mount them on the 'K' frames, and do the installation from under-neath.
I believe your first sentence is the answer. I copied this from a discussion that was held some time ago.How does one determine production date based on the VIN, or is this saying they know of specific VINs with specific build dates?
And were these cars sold to the public?
Not asking you specifically, just asking.
I mentioned that. So far as I know this amounts to a "c" body block The manifolds WERE inferior. The engine was de-rated in power because of them383 blocks are not all the same. In the Barracuda (and assume Dart) the motor mount uses the forward mount position on the driver's side to clear the steering box. Not all 383 blocks have the needed forward bolt locations cast or threaded into it. I have seen these castings on earlier '60's engines. When installed in a 'A' body, then the rear most "standard" motor mount ear is cut off. Hence a 383 in an 'A' body uses only the forward motor mount ear and bolt holes in the front of the block. The exhaust manifolds are not 'inferior' but rather necessary to wrap around the steering column but causing a power loss. The factory is not obligated to provide header clearance.
Looking for understand.
Who is Paul?
Wasn't under-neath installation common practice, wouldn't they start there?
I don't recall the exact steps I took to remove my original engine, but I believe I couldn't pull it up and out with the exhaust manifolds on it.
It doesn't seem practical to engineer a car that requires manual install of the engine from above, and it just so happens that same thought process allows an easy install from the bottom.
No 440s in 68 Darts - 69 only
They offered 383s in 68 and 69 along with the 440 in 69
...and they put 440's in '69 Barracuda's.
and 68 Darts, 69 Darts and they were RB blocks
The only 440's in 68 Darts were GSS's done by Mr. Norm... About 50 of them were made, I knew a guy that used to have one of those when I was younger...
Not asking you specifically, just asking.\
I believe Car & Driver did a road test on a pre-production 383 Barracuda in August/September 1966, but this wasn't available to the public yet. Also, most all pre-production cars ended up being crushed.
