Just as an FYI for you guys that are really pushing the limits of your 1200PA, theres a guy on the Facebook group offering decapped and flow tested 120 lb drop-in injectors. I think the factory Fitech's are 80lb.
I used this one on mine and it works fine. Will try to take pictures of it on the car this weekend. sAccelerator cable and bracket question. 1971 Demon 340 with an Edelbrock RPM Airgap, Fitech and 6 spd so no need for kickdown. What bracket/cable is recommended. My car came with nothing beside a pedal. Pics would be extra appreciated!!
I used the standard bracket and cable on my 67 340 Barracuda with the Fitech and air gap. They should be available from the resto places.Accelerator cable and bracket question. 1971 Demon 340 with an Edelbrock RPM Airgap, Fitech and 6 spd so no need for kickdown. What bracket/cable is recommended. My car came with nothing beside a pedal. Pics would be extra appreciated!!
I believe the OEs do it for getting the engine and catalyst up to proper temp quicker and able to go into closed loop. My FITech idles up slightly maybe 100-200 over target when first started. Once in gear it maintains the AFRs and idles normally.I'm guessing here, but I don't see a reason for a high idle as long as the AFR is managed based on the temp.
Here are some pics. Not much to the install. Tell me what you want to see and I will take a pic. Also, any questions ask away. I will try and answer.
