70Duster440
Did you make that throttle linkage, or buy it?
Does it use the stock throttle cable?
I have the same on a tunnel ram, the current setup is hurting, and l'm having difficulty finding inline linkage that is good quality.
A little off topic and I can’t speak for Jack but I used a common inline linkage setup and fabbed some small brackets to get the correct geometry in order to use a Mopar throttle cable and Bouchillon kickdown setup. It’s changed a little since this pic was taken but the idea is same. Cable clamps and attaches at bottom.
Like kits here: Linkage Kits
