[WANTED] Fittings for heater hoses
DRENO
Winnipeg,Canada
Need the fittings for the heater hoses on my 340. The one for the intake and the one for the water pump. The diameter of the pipes from the heater core are 5/8". I also need the finish plate that holds the rubber gasket on around the heater pipes at the firewall. The gasket I will make myself.
Hi Dave they make repop set for sale on ebay and I will check for a firewall plate for you.
You don't need one for the water pump. The heater hose slips over the nipple that's there. Looks like someone threaded the i.d. of the nipple. Most likely cause they bypassed the heater core and needed to plug it.
Thanks fishy,that explains it. I'm no mechanic and haven't got the experience a lot of you have but I am trying to do what I can on my own. It was the water pump one that had me confused.
