CudaFactHackJob
The pic in post #25 shows a weight.
Even the flex plate you want shows an elongated hole..
Because this is the only one I had, my car was disassembled and needed to have mobility. Local “pro’s” adviced to try, I’ve tried. Shipping any other plate takes month and the half...Yep, the TCI 145700 is for an internal balance 360 engine. Didn't we determine a while back that your 360 is external balance? I'm having a difficult time understanding why you'd install this one.
So I've bought it! and this is the 4th flexplate and it's not fit it's 10` and I need 11`. Ordered the B&M 10236, I know it's wrong weight, I know it's for 360 and not for magnum but this is the best choice I have. Need your advice here - what if!!! I'll cut a small piece on the opposite side of the "cut" the 10360 have? it should balance 500+ grams, I need 314 grams, so if I'll cut a small piece - will it help to be closer from 500 to 300 grams I need for my magnum?What? The answer is the ATP Z-332!
Will try it later. Drilling is not an option as I have all plates smaller than needed. Only one that is for internal balance is ok in terms of diametr. I’ll use this one but it’s for 360, too much “balanced”.Can u post pics of plate and converter? What about drilling the right plate if u have it? Kim
For example, the required amount of off-set on the balancer end is 534.3 grams for the 360 and 314.4 grams for the 5.9 Magnum. The rear end of the engine has the same thing going on, on average there's only about 60% of the weight off-set that the 360 has compared to the Magnum.How much weight difference is there. I think an LA. 360 is 19+ oz. What about a 400/440 cast crank plate. I believe it’s 12+ oz, but not positive. What is the magnums weight? Kim
Can you please measure the distance between the holes like I've posted earlier? looks like the "cut" is smaller and it should balance an engine better than 10236.More
Thanks a lot!Alrighty, I measured the same as ur pic. The outside holes are approx 11 1/8 inch ctc. The inside holes are 9 7/8 Inch ctc. The cutout may not be in the same place. I also measured from the outside bolt hole to the tip of the cutout. Left side 2 in. Right side 1 1/2 in. Kim
Hi, the story is not ended... after installation of 10237 flexplate vibration increased! I'm devastated... dead end. Any ideas why it can happen? Just a reminder - I have Magnum, from Jeep Cherokee, 5.9l plus 727 transmissionFinally, if you have Magnum and 727 transmission - 10237 is your choice
hope my experience will help someone View attachment 1715572411
Thanks for asking. Converter is balanced by itself. On the black plate weight is marked with white.Is there a weight on the black plate. If so, where. Is there a weigHt on the converter?
Kim
