rednesss
Just remove the screws after it's set up, and then tape the back side of the hole and then mix up a little bit more panel bond adhesive and fill in the holes. Voila, problem solved.
The authentic stuff or the cheap knock off??
Remember if you go with the cheap knock stuff to use twice as much.
