Not mine
I'm assuming that the 3 grand is not for both cylinder heads?
I’m sure it would be for both heads.I'm assuming that the 3 grand is not for both cylinder heads?
Because mopars just happen to be the most expensive engine to build. I'm sure that there is a lot of R&D in the development of those cylinder heads.Why not? I’m not sure I’d pay 3 grand for those. They take a huge amount of work.
I don't know anything about the w cylinder heads, why do they require special valve train parts?I’d pay 3K for the pair.
I’d tell you to jump off a very high bridge for 3K per head.
And not so kindly ether.
Part of the problem is “IF” they can be ported out to the maximum. If not, then they can be no better than an Edelbrock/Chink knock off head. Mine went only 312cfm before a port gave up the ghost.
The other problem is an expensive valve train. TD or Jesel here kids. That equals “KA-Ching!” (AKA - Lot-O-money.)
The heads are basically stated as an aluminum square port version of the W2 & can be ported out a little further for more flow. YMMV.
The research that I've done lately says the same thingGo find the equivalent GM or Ford head to the W5 and see what that costs. It’s the same.
When you could go buy junk yard parts and race the GM stuff was cheaper. When you step up to race parts the cost is very similar between all the brands.
Milled rocker stands requiring ether TD, Jesel or Crane/MP rocker set up.I don't know anything about the w cylinder heads, why do they require special valve train parts?
Then you have to buy all of the rocker gear.Why not? I’m not sure I’d pay 3 grand for those. They take a huge amount of work.
Do you have a Mopar yet?I don't know anything about the w cylinder heads, why do they require special valve train parts?
???No GM or Ford is using stud mounted rockers. All shafts unless they are stuck in the 1950’s.
Disagree! Not true. I’ll just say any serious Chevy or Ford is using a shaft mounted rocker. I’ll leave it at that.So do they. No GM or Ford is using stud mounted rockers. All shafts unless they are stuck in the 1950’s.
wasn't the W2 offering with the pedestals called "econo" or some such? and did it have dual pattern exhaust mounts?The W5 has them milled off, all of them. W2 came both ways.
arr matey! when ye be gettin' into tall masted ships they all be the same price!Because mopars just happen to be the most expensive engine to build. I'm sure that there is a lot of R&D in the development of those cylinder heads.
Got 2 to check out in the next few days, both in IllinoisDo you have a Mopar yet?
Its a really good time to be a small block mopar guy
