here may be the answer you need....this is copied from another website. hope this helps!
Granada rear-end in a Mopar A-body?
The Ford axle is an 8" unit. So yes, its stronger than a 7.25" (anything is). The center drops out like the Chrysler 8 3/4 and Ford 9". If so, its a good thing. The only drawback to an 8" is that gears and posi units are harder to find than an 8-3/4.
The 8" Ford is a drop in replacement. Everything lines up, you need to use the mopar parking brake cables and a Ford/Mopar adapter U-joint.
The overall width of the Granadas 8" Ford axle is 57", the overall width of an A-body axle is 56 1/4". The spring perches are the same at 43".
The 8" Ford axle from the Granada is 3/4" wider then the standard A-body axle. The spring perches are in the same location. They use 3" U bolts, so 8.25", 8.75", 9.25" shock plates are needed. The 7.25" driveshaft should bolt on with an combination U joint. I would suspect that they weight about the same as the 8.25". Street Rodder has an article on the available drum brake packages for this axle in the current issue (two Ford, one Currie). There are several disk brake setup available, one from CE, one from Currie and there are most likely others.
Some Granadas had 9" units! , check the bottom bolt. if you can fit a box end wrench on it 8", if only an open end fits, 9" !
The Ford 9" and/or 8.75" axles will be found behind 351 powered Granadas/Monarchs. Everything else, used the 8" axle. Avoid the 8.75" axle, it is not supported by the aftermarket nor Ford. This axle can be identified by the bolt on rear cover. It looks vaguely like the 8.8" axle.
