View attachment 1715464190 All this is for older than mine so if any one can use them you can have them
Boy that plane wound intimidate the heck outta me!
What are those "extras" Fred?
View attachment 1715466952 67 to about 70 tail light and side marker sockets and front park lamps I'm guessing. will never use them so thinking someone can.
They plug in to the lamp but wiring plug in is different.I may be interested in them Fred, are the connectors OEM style?
I work on aircraft sheetmetal every day. Lycoming or continental? Carbed or injected? IP is looking good so far. The Kaiser 7075 T6 aluminum is some of what we keep in the rack in the department I run. What kind of avionics are going in the monster hole? Our RJs run Honeywell Primus systems. Older system, but might be a bit advanced for a prop job. Looks like it's a kit plane. Is it a home built you guys are refreshing?View attachment 1715466405 View attachment 1715466406 Worked on the plane with my boys today scrapping paint off replacing the dash and up grading the instruments as well as replacing all the switches and anything that looked bad.
My wiring kit on my car came with all the wires marked with there placement. Like left turn right turn and was pretty simple but paid 1,000 for the kit.But it's done and everything works but having problems with the back up lights not working all the time so guessing the neutral safety switch is bad.I work on aircraft sheetmetal every day. Lycoming or continental? Carbed or injected? IP is looking good so far. The Kaiser 7075 T6 aluminum is some of what we keep in the rack in the department I run. What kind of avionics are going in the monster hole? Our RJs run Honeywell Primus systems. Older system, but might be a bit advanced for a prop job. Looks like it's a kit plane. Is it a home built you guys are refreshing?
4spdragtop, it's really not that intimidating after you seperate the systems out, just like on a car. What is intimidating is wiring though. Everything is the same color with only number tracers printed on the wires every foot or so. Nothing is typically color coded. I love auto electric trouble shooting but not aircraft, that's why I am a tin bender.
I would like to have it on the road by first part of May but not gonna rush it.Fred, you should have it up and running by spring at this rate !View attachment 1715476019
Yea big distance from Mo.I will be in Mo. sometime in May, visiting family, won't be able to make that .
I bet it feels good can hardly wait till mines done.I'm 1300 miles from Mo. from here. plus more to MINN.
Hope you get it done by then. Been putting some miles on mine , Runs good, rides nice and the modern seats make it feel like a new car.
O-320 Lycoming. Workhorse of the industry. And a fine airboat engine.View attachment 1715468287 View attachment 1715468288 I don't know anything about aircraft but if you can read the tag it's 150 HP. he bought it out of California last summer and had the top end rebuilt by the pros and flew it here. The big hole in the dash is an upgraded dash all computerized should be here in a week I have know idea what my son bought but he was looking at 2 different ones 4 to 8 grand. I'm just the painter so I leave all the tech. stuff to my son. When we finish the plane we will pay a in specter to check it over real good before it ever leaves the ground.
Not yet Steve replaced the neutral safety switch and still having problems. The good part is it won't start in gear so that's a plus.You get the backup lights figured out Fred? Absolutely beautiful.
I like it how fast is that.O-320 Lycoming. Workhorse of the industry. And a fine airboat engine.
View attachment 1715476041 View attachment 1715476042 View attachment 1715476043
