It may not be a bad idea to look for a set of Brodix B1-BA heads.
Don’t you port heads? What do you have on the shelf?As for the BB or SB 446........ it was 30 years ago........I don’t think anyone was building 446” SB mopars in 1990.
How about a pair of Trick Flow 190 ?I’m opened to getting most heads...would like them to be aluminum...but I don’t think I will go as far as the Indy heads...they are a bit rich for a free cam build and should really be used with a roller cam
That’s the way I’m leaning...unless someone has some ported eddies l can grabHow about a pair of Trick Flow 190 ?
Could you explain ...thanks452 sbc in 62 but sbm somewhere around 3.8 stroke
So could someone explain why this cam is frowned upon... nobody really likes it
I have the 4:56 gears on the shelf and don’t care if I have to run a 4500 stall as the car will never go too far from home…( unless I do Drag Week again ) I would like it to run on pump gas so 12:1 may be pushing it…but by run on pump gas I mean as long as it can drive to the burger stand on pump gas that’s good enough…if I take it to the track I have no problem running race gas when I beat on it…
I’m going to stop at the machine shop this week and talk about heads…should I go with off the shelf or order bare and have them install larger valves…
Anyone want to do one of those cam timing cylinder pressure calculations for me to see what I should shoot for as far as compression?
So PRH for someone like me who doesn’t speak camshaft …what will my free cam do right or wrong?
I’m going to go with a 340 block as I already have a new 4” forged crank for one that I purchased a few years ago when I was going to buy some Bloomer heads...I will take your advice and do flat top pistons although I will likely get them custom made to match the combustion chamber to get the quench tight408 with flat tops, zero deck, 60cc heads will put you right at about 12:1.
The car is a complete 80s throw back so the engine may as well be too... I have to figure out the heads soon as the Canadian dollar is tanking fastWell, it’s what I call an “Honest Build” anyway. It doesn’t have a clever cam marketed under a fad name to make it sound like it has a drag race cam in it. It’s going to sound like it has a drag racing cam in it because the cam was actually designed for drag racing, even if it was back in the eighties. Very few things are more fun than a than this level of street brawler.
