67autocross
A new iron curtain drawn across the 49th parallel
The free cam will still be a free cam at the end of the build...Sounds like the “free cam” build is gonna get expensive.
I did not know you could do that.No.. they are 59 degree heads so they should work on a factory block
Not sure why it’s a waste... with a little work they will flow in the lower 300 range and will make as much power as the stock block can handle... even with the free camI did not know you could do that.
Seems like a waste not to use the heads to they full design capacity.
It is done on most every build save a serious racer or a nut job on the street that has to have every last HP... or actually what he thinks he is doing....I did not know you could do that.
They flow 290/300 OOTB if not really close to it.
More assumptions!
At the end of the day this is all about what you can do with a free cam...It is done on most every build save a serious racer or a nut job on the street that has to have every last HP... or actually what he thinks he is doing....
(Enter Gradfather clock Coo coo birds sounds...)
Oh yea I get it but that reply was for the quoted and not you.At the end of the day this is all about what you can do with a free cam...
wow, i saw the ad....Facebook w-Head site? Nice stuff!!!
Michael
Michael
Man-O-Man do I hear that! Ditto and then some.I've been "Can't doing that" for 35 years since.
But if you just put some 273 heads on that sucker it'll be plenty streetable.
Restrictor plate style.
What brand of cam was that?That's what i would do. The original engine combo i had when i bought the car had a set of cleaned up 302's with a 1.84 valve and a 320 adv 256 @ 0.050 490 108 lift solid cam. That incarnation ran the hardest of all the combos Ive tried. The torque through out the entire rev range was incredible.
Its really cheap too......
David Visard cam?
https://www.amazon.com/dp/0863430414/?tag=fabo03-20
Now I need to start figuring out what parts I need to run the W9 heads on a 59 degree block... I assume some kind of offset rockers... and push rod oiling possibly...Glad to see you diggin your heels in on keeping the cam. Most of these pushovers on here would have thrown the free cam in the garbage and run something a "guru" told them. I love your direction. This is going to be a FUN build and that's what it's all about!
