67autocross
A new iron curtain drawn across the 49th parallel
Well rockers will something I have to source...plus figuring out the push rod oiling with the solid lifter cam...look good!
What else are you needing to make this set up complete?
I was told only Jesel and T&D make the rockers for these heads...
I’m just using a factory 340 block...
That's correct...I was talking lifters. The Crane Ultra Pro lifters for pushrod oiling is part number 69550-16. If you are going to use an R block with tall lifter bores then you need 69554-16.
The free cam is a flat tappet piece.
I’m assuming I use AMC lifters like when you put Magnum heads on an LA blockDammit. Lost my mind.
Disregard everything I typed.
I gave away a set of resurfaced solid lifters for pushrod oiling. Too bad I didn't keep them, as I would have given them 67.
OK you got me with the AMC liftersI’m assuming I use AMC lifters like when you put Magnum heads on an LA block
What is the difference with AMC vs SBM ?
Like a certain candidates 1.5 trillion "Free Health care" plan. Use the word free and its all ears..aka ..hook , line.. n sinker.Sounds like the “free cam” build is gonna get expensive.
So let me understandAMC lifters are .904 diameter and have pushrod oiling capabilty, the standard Chrysler solids don't have PR oiling.
They are either setup for LA oiling or MAGNUM style push rod oiling.So let me understand
If you dont do shaft oiling you would need to do pushrod oiling - correct?
Do aftermarket heads do shaft oiling?
Thanks in advance
I would guess that headers may not be something that the local speedy mart has in stock...
So do, some don’t.
Like almost everything else in hot rodding......”it depends”.
The W9’s the OP is planning on using for this build don’t use stock LA oiling.
So, the choices are PR oiling or spray bar oiling.
What do you think is the better option for pistons...order custom or buy off the shelf stroker pistons and cut the valve reliefs for the W9 valve angle?
