Rear leafs are from Hotchkis, which lower 1" from factory (part 24385). Torsion bars, not too sure but they looks to be 1" or slightly smaller.Do you know what bars you have and rear leafs ? Reason I ask is how is the ride that low. I’d like to get mine an inch lower, but if I lower the ft the rear will come up.
Rear sits at 26 1/2 with the leafs on P255/60R15'sI’m at 27’’ rear and 26 1/2’’ ft
First we all need to know what engine your car was built with and what engine it has in it now. Chrysler used THREE different torision bars depending on whether or not the car had a/c and the engine installed. Plain /6 cars got the smallest bar. /6 cars with a/c and 318 non a/c cars got a bigger bar. 318 cars with a/c and 340 cars got a bigger bar yet. These bars are .892". They should likely be your minimum bar. For shocks, I've always relied on and loved KYBs. I've had Gabriels and hated them. Does your car have front and rear sway bars? If not it should. If they're mounted in rubber, they should be mounted in polyurethane. AND most important, the front sway bar HAS to be bigger than the rear bar. Unless you're anxious to kill yourself. Chrysler designed their cars to understeer straight out of the factory. Adding a front bar reduces that. Adding a rear bar puts it back in. Having a rear bar bigger than the front bar is a recipe for monstrous snap oversteer that you'll never catch.Looking for some front shock recommendations for my 68 Barracuda. Currently, the shocks installed seem to be bottoming out when hitting bumps. Front is sitting lower than stock (about 23 1/2" from floor to bottom of fender) Tires - P205/60R15. Not too sure what other details I can provide here to make a solid recommendation. Looking for something a bit more stiff I'd imagine so I don't bottom out.
Car was originally a slant 6 without AC. It now has an LA360. No sway bars at this time.First we all need to know what engine your car was built with and what engine it has in it now. Chrysler used THREE different torision bars depending on whether or not the car had a/c and the engine installed. Plain /6 cars got the smallest bar. /6 cars with a/c and 318 non a/c cars got a bigger bar. 318 cars with a/c and 340 cars got a bigger bar yet. These bars are .892". They should likely be your minimum bar. For shocks, I've always relied on and loved KYBs. I've had Gabriels and hated them. Does your car have front and rear sway bars? If not it should. If they're mounted in rubber, they should be mounted in polyurethane. AND most important, the front sway bar HAS to be bigger than the rear bar. Unless you're anxious to kill yourself. Chrysler designed their cars to understeer straight out of the factory. Adding a front bar reduces that. Adding a rear bar puts it back in. Having a rear bar bigger than the front bar is a recipe for monstrous snap oversteer that you'll never catch.
Good....Don't flip the hanger.No it’s all in stock position.
Hotchkis - front 22385F
Yes, the QA1 front sway bar is specifically to be used with their K-members. But also note that it can be used with stock lower control arms HOWEVER it has be ones from 73 and up with sway bar tabs.Ordering front/rear sway bars here soon. Looking at Hotchkis and QA1. Any recommendations one over the other or another brand? Hotchkis - front 22385F , rear 22385R. QA1 - front 52861 , rear 52830. However, QA1 may be specific to a QA1 K member.
Noted. My LCA's are 68 so no go on the QA1's.Yes, the QA1 front sway bar is specifically to be used with their K-members. But also note that it can be used with stock lower control arms HOWEVER it has be ones from 73 and up with sway bar tabs.
Does it come with all the necessary hardware? May check it out regardless of aesthetics.thats supposed to be the best on the market but also looks like a freaking locomotive cattle guard hanging from the front of the car. i had one and sold it because of that before even installing it.
Currently running 205/60R15's with rear mounted calipers. Is the wide tire clearance sway bar a must with this setup?Hellwig
Try to get the front one made for wide front tire clearance. Might not need it now, but could in future
Rear sway bar adjustable version
Also, not too sure if this matters but this is the rest of the front suspension setup.Currently running 205/60R15's with rear mounted calipers. Is the wide tire clearance sway bar a must with this setup?
