I don't know. There are other outlets on some of the tanks.That makes sense. So are the caps vented on these then
That went to the vapor recovery system.
I am using a similar filter on a LS1 in my truck. They came in corvettes. It's actually a regulator and filter in one. Whatever the engine won't use or what's over the psi of the regulator it diverts it back to the tank. I wonder if it's a similar deal.I've read Alot of Good things about the 3 way Wix Filters here..
I'm not sure. I've never used one like that. The one Dana67Dart was referring to is a filter, with an extra outlet, if it's what I'm thinkingI am using a similar filter on a LS1 in my truck. They came in corvettes. It's actually a regulator and filter in one. Whatever the engine won't use or what's over the psi of the regulator it diverts it back to the tank. I wonder if it's a similar deal.
Hmm, makes me wonder if I got an early tank, to eliminate the extra nipples.I don't know. There are other outlets on some of the tanks.
My understanding is there is a very small orifice that bleeds the vapor and a tiny amount of fuel but you still get more than enough fuel to run the engine.am using a similar filter on a LS1 in my truck. They came in corvettes. It's actually a regulator and filter in one. Whatever the engine won't use or what's over the psi of the regulator it diverts it back to the tank. I wonder if it's a similar deal
All I remember is my car would idle, but die at the most inconvenient time! But a 5/16 and a 1/4 were rolling into the bay. Demoed it all, and attacked with new, then all was well...Not all tanks had them. It was a year thing.
Probably 76 is most likely to have multiple nipples.
That's Cool Man!My understanding is there is a very small orifice that bleeds the vapor and a tiny amount of fuel but you still get more than enough fuel to run the engine.
We did something similar to this when I raced outlaw karts with cr500 engines. We would put a carb jet in the return line otherwise it would starve the carb for fuel and just send it all back to the tank. Interesting how stuff crosses over.My understanding is there is a very small orifice that bleeds the vapor and a tiny amount of fuel but you still get more than enough fuel to run the engine.
This was used on my 79 440-6 RR. They work well. Wix (and others) make fuel filters with this built in.My understanding is there is a very small orifice that bleeds the vapor and a tiny amount of fuel but you still get more than enough fuel to run the engine.
