The first 2 pix I was getting ready to primer the whole *** end after sandblasting. I wasnt too concerned about that at the moment as I was not sticking sheetmetal back in yet. Additionally the framerails , tiebar, and rear valance were still attached together when I took those pix. I removed enough for sandblasting and left about a 1" strip the width of the trunk from the trunk floor tying it together for a moment. I removed that when I started on the trunk pan. Not sure what your talking about with the datum plane in regards to an automobile. I deal with specific datum in regards to aircraft. However if you use a level across the radiator support upper flange and across the transition pan that gets your car level side to side. If having to shim between the stands and the frame to get it level shows that your floor is not dead level. Its concrete. It will be close eyeballing it, but wont be perfect. Once you got the front and rear level side to side, then you put levels on the rockers, and shim and level it front to back. So far everything seems to line up for me. If rather be a little over cautious and double and triple check and not have to drill something back apart. Again I am saying do it how you want to, I will do it my way.
