berry-cuda
Hey guys setting up my new ring and pinion and was wondering your thoughts on the gear pattern I have, not sure if it's ok or to add more shim to the pinion thanks
Yeah I was thinking that, is that corrected by moving pinion depth closer to ring gear?
The carrier needs to move towards the pinion so the ring gear will engage the pinion deeper. Other than that, it looks good.
I'm lookin at Taiwan in the first pic !!!I think he has the pinion gear depth dead on. In that first picture, you're lookin at the drive side of the ring gear teeth. That's the most important side and it's right on the money. That's my opinion and I'm stickin with it. lol
Yeah eaton true trac made in TaiwanI'm lookin at Taiwan in the first pic !!!
8 3/4 with 3:91 and true trac
Yeah I have the backlash set already, so should I leave everything the way it is? And not move the ring gear closer?
