younggun2.0
well i have had my car running for the last year now and I am just now getting things wrapped up and getting it ready to head to the track for the first time. I started with an intake swap this weekend. I went from the mopar M1 single plane to a Eddy performer RPM. I noticed an increase in the low end torque and mid range power. this is all seat of the pants but it was noticeable.
I also order a new stall converter from Dynamic this afternoon. ordered up an 9 1/2" 4500 rpm stall converter with all the goodies. should really wake up the combo.
here are my specs. let me know if anyone has any advice to optimize my combo.
67 dart
383 stock bottom end rebuild with speed pro pistons installed at zero deck.
84cc eddy heads mild port work, gasket matched
comp cams 284s cam. 525 lift .254 @ .050 duration
tti headers 1 3/4" primary
tti 3 inch x-pipe exhaust dumped before the rear dif.
eddy performer rpm intake
750 proform holley carb.
727 with cheetah forward pattern manual valve body
4500 stall 9.5" dynamic converter
moser fabricated 8 3/4 rear with 4.10 rear gear
28" x12" drag radials.
67 dart
