Getting the Intake on Intake Manifolds
Hipolito,
Do not despair.
Back in the day, Holley produced '2' different type of 'Street Dominator'' Intakes for
the 'Mopar 318'
* 300-7 {ie; 300-29Z} ....... 'Open-Plenum'
* 701R-29Z ...................... 'Split-Divider' with Rear Balance Tube
Both were listed as 'Medium-Riser' Single-Plane Intakes, with a 'Low-Profile' design.
______________________________________________________________
'Holley' advertisement >
Specifically designed for 'Stock-to-Mild' 318 Engines, and with a recommended use of a 600 CFM Carburetor, primarily the 'later' Thermoquads found on the 318 >
{which are rated anywhere between 520 CFM's and 650 CFM's, depending on who you talk to}.
The {#300-7} has an 'Open-Plenum', with slightly curved runners which
provides for a 'fatter' torque-curve.
The Ports are designed for 'Small-Port' 273/318 Cylinder Heads, and the
runner-ports are both 'curved and smooth' to provide for a quicker
throttle response over a 'stock' Intake.
The {#300-7} delivers very good 'Low-End' Torque, because of the massive
restriction under the plenum.
It performs well from 1000 to 4800 RPM's.
The {#300-7} has a Carburetor Flange opening designed for a
Carter Thermoquad Carburetor.
What was 'not' stated >
The {#300-7} has poor breathing above 4800 RPM's.
Are you trying to give yourself a headache Paul? Some back-to-back dyno numbers would
be swell like in the recently referenced 383 and 440 intake manifold tests.
That Weiand #7507 does look virtually identical to the LD-340. Coincidence? Probably not.
Where do the Air Gap and Air Gap RPM play into this? (seeing as how I just bought an RPM)
Great thread, BTW!!!
Hipolito,
Do not despair.
the 'Mopar 318'
{which are rated anywhere between 580 CFM's and 650 CFM's, depending on who you talk to}.
http://i362.photobucket.com/albums/.../Holley Street Dominator/HolleyStreetDom1.jpg
The lightweight Aluminum Intake weighs in at a 'very light' {17 lbs.}.
What I know thru testing.
On a '273 Commando', the Holley {#300-7} Street Dominator put out
{+7 Horsepower} over the 'stock' Cast Iron Intake @ 4000 RPM's.
The 273 responded better with the 'Street Dominator' {over the 'stock' Cast Iron Intake} thru the Bottom-End.
On the 'Track', we gained an average of {-.12} lower Elapsed Times.
But, the MPH was 'identical'.
Brockway Bill,
I have found that the Thermoquad from the '1978' 318 Truck Engine
#9123 {M/T}
#9124 {A/T}
Works best with the 'Holley' {300-7} 'Strip Dominator', especially on a 'Stock'
or 'Mild' 318 Engine.
Usually with no more than Headers {or a good tuned Exhaust System}.
And with a 'Hydraulic' Camshaft with a Lift of .445" and Advertised Duration of 260*.
Any Camshaft that was more 'radical' than the above specifications, was a wasted effort with the Holley 'Street Dominator'.
These Carter Thermoquads came thru with;
* Primary Jets .......... .092"
* Secondary Jets ...... .110"
Depending on who you talk to, these 1978 'Thermoquads' were rated
at anywhere between > {580 CFM's} to {650 CFM's.}
SOrry to revive and old (but interesting thread). The LD340 was released in 1969 (correct?). When released was it the version with or without a Chrysler part number (I know there were two versions)?
Great info Paul. Don't know how I missed it. Thanks.
not having a 340, or small block for that matter, I didn`t read all the posts. I was hoping for a pic of judy lilly driving one of her superstockers in a mini dress . anyone remember that ?
Just came across this thread by accident. Was just thinking of Paul yesterday. I miss the 'MatchRace" series that he did. RIP Big Guy.
I was hoping for a pic of judy lilly driving one of her superstockers in a mini dress . anyone remember that ?[/QUOTE]
Like this?
Which has what to do with this thread?
Put it in the babe section where it belongs.
