1. pistolpete1934
    pistolpete1934 Member
    13
    2
    Jul 7, 2020
    Ontario
    Local Time:
    3:28 AM
    Does anyone have any feed back regarding the Summit GM style distributor on their small block. I know you get what you pay for but even if you have to replace the coil and or module is the rest of the distributor of decent quality? Looks huge!
    Thanx guys...
  2. Hellrats
    Hellrats Just another dumbass FABO Gold Member
    1,302
    1038
    Jan 24, 2012
    N.E. Ohio
    Local Time:
    3:28 AM
    It is big. If you want to go GM style HEI, which work quit well, you can go this route Mopar HEI Conversion and keep your factory distributor. This way you still have the factory advance curve and it's less money.
    • Agree Agree x 4
    • Like Like x 1
    • 67Dart273
      67Dart273 FABO Gold Member FABO Gold Member
      45,155
      12796
      Oct 14, 2010
      Idaho
      Local Time:
      12:28 AM
      Well which specific setup are you talking about? There are many ways down this road, some of which are not truly GM or not HEI.
      Many of us use a stock Mopar or performance distributor to trigger a stand alone GM HEI module, either 4 pin or 8 pin or whatever. "A DIY system."
      Some of the 1 piece "ready to run" distributors are not really HEI. Some of the "big GM cap" HEI distributors might be of questionable import quality
      • Like Like x 1
      • moparmat2000
        moparmat2000 FABO Gold Member FABO Gold Member
        17,169
        6152
        May 13, 2010
        Grand Tetons
        Local Time:
        2:28 AM
        Use a mopar vac advance electronic distributor, add this bracket from www.designed2drive.com and a GM HEI 4 pin module.
        Halifaxhops on here redoes mopar electronic distributors
        • Like Like x 4
        • Thanks! Thanks! x 1
        • Agree Agree x 1
        • vitamindart
          vitamindart Well-Known Member
          1,231
          327
          Jun 11, 2010
          Vernon,Wisconsin
          Local Time:
          2:28 AM
          I have that bracket works nice, keeps everything nice and compact
          • Agree Agree x 1
          • moparmat2000
            17,169
            6152
            May 13, 2010
            Grand Tetons
            Local Time:
            2:28 AM
            Yep hides it real good. Add a pertronix igniter lll oil filled coil and its almost stock looking.
          • RustyRatRod
            RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
            64,864
            37825
            Jun 7, 2010
            Georgia
            Local Time:
            3:28 AM
            The Summit is the same as all the rest that come from China. Don't let that scare you because they are pretty dang good. I've had one in the 351M in my 75 F250 for about 5 or so years now. Runs like a top.
            To me, the HUGE advantage is, IF you have room for that big ole cap, go for it. I say that because replacement parts are available EVERYWHERE. Who doesn't keep a 4 pin Chevy HEI module in stock? Hell, our local WalMart even has them. That's no joke. That's their biggest advantage right there.
            Get a Pertronix? Great! Break down on a Sunday afternoon and get back to me. LOL
            • Agree Agree x 2
            • pistolpete1934
              13
              2
              Jul 7, 2020
              Ontario
              Local Time:
              3:28 AM
              thats kinda why i looked at these because of the availability everywhere of the GM ignition parts... just dont know if it will clear A body firewall...
            • RustyRatRod
              64,864
              37825
              Jun 7, 2010
              Georgia
              Local Time:
              3:28 AM
              If it won't, you can do like Del (@67Dart273) said and build your own. It's very easy. There are plenty of diagrams out there to follow, too.
            • ed1946
              ed1946 FABO Gold Member FABO Gold Member
              159
              55
              Apr 24, 2019
              garrison, ky
              Local Time:
              3:28 AM
              I've got the GM one in my 72 with 5.9 magnum motor. I like them because 1 wire hookup.
            • Eric Mulay
              Eric Mulay Well-Known Member
              46
              1
              Dec 23, 2019
              san luis obispo california
              Local Time:
              12:28 AM
              I have a 1974 duster
              i have one also on my magnum, but,, i can not seam to find a constant HOT wire,
              how did you wire this?
            • 67Dart273
              45,155
              12796
              Oct 14, 2010
              Idaho
              Local Time:
              12:28 AM
              In what? What car are you installing it in? Dammit people we cannot imagine what you are working on. I don't have the gift of mental telepath, and Rusty cannot ever find his damn crystal ball.
              1943 Supermarine Spitfires use twin magnetos, they don't NEED a hot wire
              ............and if you are swapping a hemi into a '28 Farmall, I have no idea what was done with the wiring......
            • Eric Mulay
              46
              1
              Dec 23, 2019
              Local Time:
              12:28 AM
            • 67Dart273
              45,155
              12796
              Oct 14, 2010
              Idaho
              Local Time:
              12:28 AM
              OK. In these Mopars there is only one source for switched ignition under the hood and it entails TWO wires
              IGN1 or "ignition run" usually dark blue, comes out through the bulkhead, is NOT fused!!! and feeds the ballast, the VR, the alternator field, and some smog doo dads if equipped, as well as electric choke if used.
              BUT THIS GOES DEAD when starting.
              The starting voltage---to the ignition system is........
              IGN2, normally brown. It comes of a separate, dedicated contact on the ignition switch, and feeds to the coil+ side of the ballast resistor
              SO if you are installing an igntion--like HEI--that does not use a ballast, you must jumper the IGN1 and IGN2 together--without separating the other stuff it feeds......and hook that to your new ignition
              "The easy" way to do this is to jumper the ballast connector terminals together and then connect the original coil+ wire to the new ignition.
            • Eric Mulay
              46
              1
              Dec 23, 2019
              Local Time:
              12:28 AM
              But won't that give constant power to both lines if you just hook them together? And one isnt supposed to have constant power?
            • ed1946
              159
              55
              Apr 24, 2019
              garrison, ky
              Local Time:
              3:28 AM
              This is how I did mine and did away with ballast resister
            • 67Dart273
              45,155
              12796
              Oct 14, 2010
              Idaho
              Local Time:
              12:28 AM
              No. IGN1 is hot in "run." It goes DEAD in "start"
              IGN2 is only hot in "start."
              Why?
              Because when you twist the key to "start" and if there was no IGN2, the coil would see battery at cranking voltage minus the drop through the ballast = VERY low coil voltage in "start" perhaps less than 6V
              So IGN2 jumpers full battery voltage from the key direct to the coil in "start." Since the battery sags during cranking, this means the coil gets around 10.5--11.5V during cranking.
              • Eric Mulay
                46
                1
                Dec 23, 2019
                Local Time:
                12:28 AM
                So.. Connect Q and N?
              • BillGrissom
                BillGrissom Well-Known Member
                7,376
                400
                May 10, 2009
                Sacramento
                Local Time:
                12:28 AM
                Cheapest is the "ready-to-run" HEI distributor by Ningbo (China), for ~$45 on ebay, by Steve White Performance and others. They also have one for big-blocks (~$60), but not for the slant six. It doesn't use a GM HEI module, but some other 4-pin module, perhaps for a Japanese engine. I have one but never installed. I might instead install an 8-pin GM HEI module under the cover. You also need an e-core coil. I bought one for $20. If you want to stay Mopar, take one from a Magnum V-8 engine (~1998-2002).
              • pishta
                pishta I know I'm right....
                18,341
                7840
                Oct 13, 2004
                Tustin, CA
                Local Time:
                12:28 AM
                It uses a Bosch "BIM021/024" 4 pin found in Ford/Nissan/VW. Heavy thermal grease on the bottom bolted on a thick 3/8 AL sink. Must get pretty hot!
                ZvdRY9rcOmGWkeCC7YpbYjLLVX-hnB4pCya1dkKvu3TYVzvRhR9ZEh3HRYGPDYjYuN6Cx9Ie_O0CAcBfZCoyq15Sz3d6gJ1Q.jpg
              • Mattax
                Mattax Just the facts, ma'am FABO Gold Member
                11,175
                7067
                Feb 7, 2013
                Phila. Pa
                Local Time:
                3:28 AM
                • Agree Agree x 1
                • abodyjoe
                  abodyjoe Well-Known Member
                  20,909
                  6193
                  May 22, 2004
                  Berlin,N.J. 08009
                  Local Time:
                  3:28 AM
                  i think the huge cap will fit tightly with a 2 speed wiper motor (had one on my yellow dart) but not a 3 speed wiper motor..
                • TrailBeast
                  TrailBeast AKA Mopars4us on Youtube
                  21,434
                  9051
                  Mar 11, 2011
                  Arizona
                  Local Time:
                  12:28 AM
                  I have one sitting on the shelf and the button was gone completely.:D
                  I JB welded a brass button into the cap.
                  After that I set it up with a stock magnum coil and ended up finding that the way they mounted the hall affect pickup unit in the distributor was for big blocks so the rotor phasing was WAY off. ( an assembly confusion that didn’t get caught)
                  After after redrilling and mounting it in the right place it ran really well, but screw that POS.:D
                  The person I got it from couldn’t get it to run right but couldn’t figure out why.
                  • Like Like x 1
                  • Krooser
                    Krooser Reform School Graduate
                    2,745
                    2229
                    Jul 19, 2015
                    Central Wisconsin
                    Local Time:
                    2:28 AM
                    When we had my kids SBC dirt motor built my son showed up to the engine shop with a TooCanChew GM style dizzy for the engine shop to install.
                    Gary, who owns the shop, told my kid he wouldn't allow that thing on his engine! Too many issues...loose bushings, misfires blamed on the engine builder etc.
                    We went with a stock GM HEI...
                    • Like Like x 1
                    • 67Dart273
                      45,155
                      12796
                      Oct 14, 2010
                      Idaho
                      Local Time:
                      12:28 AM
                      OK!!?? a WHUT?? LOL
