4 Large Hub Wheels 15 x 6.5 wide > prepped and sealed, ready for Silver topcoat tomorrow.
As per @ProjectBazza measurements and pictures I was able to find 15" x 5.5 pattern x 8" wide aluminum rims with the much needed 3.5" large center hole to fit the Large Hubs of the '89 D100 Truck.Hauled the truck home last night...
Cooper Discoverer H/T tires, 235/75R15, on Ford 15" rims, 5.5" bolt circle. Tread looks good, but I didn't get a "Lincolns head" picture yet, sorry.
Wheels have a 3.5" center hub (actually it's just a hair larger)...
Only thing I can't get is the width, but I'm about 90% certain they're 7", based on what I'm finding online ('95 F150 4x4).
This comes up all the time on the Ford truck forum (using Dodge wheels on Fords, and vice-versa), so this isn't new to me.
Truck runs great, but it's rustier than I thought, so I'll be parting it out soon. I will need to find a set of cheap take-offs for it (if the wheels sell before the drivetrain), so I can drive it around the yard for potential driveline purchasers...
Shoot me a PM if think you'd be interested in the wheels, otherwise I know I can sell them pretty quickly on the Ford site, or even on CL.
Jim
Removed that annoying buzzer under the dash for when the key is left in, that's a pleasant relief.
If you have any play in the steering, check the frame rail where the steering box bolts on. My 88 has a lot of play, and the frame rail is cracked. It has the add on diagonal brace, but still cracked. I'm gonna fix it when I down the truck to do the Magnum swap. It currently isn't driven other than yard driving to move firewood.
Vans had the same issue with the power steering mounts, specially with larger tires. Had mine welded 3 times.If you have any play in the steering, check the frame rail where the steering box bolts on. My 88 has a lot of play, and the frame rail is cracked. It has the add on diagonal brace, but still cracked. I'm gonna fix it when I down the truck to do the Magnum swap. It currently isn't driven other than yard driving to move firewood.
