Even a better reason to install the correct wheels.
I dislike the implication of the word "correct." That implies that anything else would be "incorrect."
I consider late model wheels on these old cars "incorrect". I don't like the look. Just personal preference and opinion.I dislike the implication of the word "correct." That implies that anything else would be "incorrect."
Technical difference: one is a very basic and simple spacer, the other has studs and is inherently safer. They make adapters that are same/same bolts pattern, so basically a spacer with studs. If you are not changing stud length then a regular spacer under 1/2" is ok, if you are looking to go wider than that, and are set on doing this with some type of spacer, then an adapter would be the way to go.
There's your problem. THe new car wheels are all backspace and no front dish like the old cars and wheels are. Does your car have disc brakes by chance? If it does that will aggravate the issue because the front track is wider than the rear (of course) and wider than drum brake cars. Your car looks good with the Rallys I would order up a pair of 7 or 8" wides (15" if you wish) with a 4-4 1/3" backspace and rock and roll. That's what I did on both cars.
'65-67 B-body 8.75 will add about 1" per side of width. You do not need to relocate the spring perches. You can drill the 7.25 shock mounts. I believe you can even use the 7.25 backing plates/brakes if you have 5x4.5 bolt pattern. Only thing will be shortening the drive shaft.
I made this video to show the swap. Complete rear ends can be bought for about 200-250 bucks, often including drums/backing plates.
8.75 being installed. 8.25 coming outWhat rear end is that? Not a 8 3/4.
I think I fixed it. lolAhhh I see. The video started in the middle.
...I don't like the look. Just personal preference and opinion.
OUR problem is the duster body is wider in the rear than your darts. We can't just make our cars look excellent with different wheels like yours do .
If that is the case and you want to use your current rear end, spacers are the only real option.I'm going for a balanced look. same spacing between wheel and fender on all 4 corners. I would also like a balanced wheel look. By that I mean I would like to use the same wheel and tire on all 4 corners rather than running staggered wheel sizes. I am not a huge fan of deep dish looking wheels. Just my personal preference. It does not have to be perfect, just wondering if it's been done before so I can start going down the path of picking wheels.
This car will never be used for more than a mild commuter and Cars and Coffee cruiser.
