front wheels are weld racing knockoffs, sold by jegs, summit, and the Actual company called "ultra wheel" i think they are a zero offset 4 inch wheel. I run a 28 inch tall skinny, which i think i would probably go down in size on tire in the future. no real reason other than looks, and i only run a 26 on the rear.
The brakes were basic wilwoods "if there is such a thing" Denny should be able to tell you what all your options are there. Dyna pro? somehting like that. basically the cheapest 4 piston calipers that they had, that fit this kit. I recommend the solid wilwood rotors, not drilled and slotted....i bought drilled and slotted, and they stress cracked with very little use. actually broke on me...and got told to pound sand. (by wilwood, not Denny) Denny was great. I'd buy a 2nd one of these in a minute.
