valiantsignet
my low beam lights stopped working.
Switch is newHere's what it looks like taken apart.
High beam switch repair
It’s a new oneThe dimmer switch is where I would start. I remember having an issue years ago. Can't remember if I replaced the dimmer switch, or cleaned up the contacts. My memory isn't the best....too much fun the late 70's early 80's...
It’s newThe dimmer switch is where I would start. I remember having an issue years ago. Can't remember if I replaced the dimmer switch, or cleaned up the contacts. My memory isn't the best....too much fun the late 70's early 80's...
Stop telling us "it's new." Here's the hard fact so please remember this FOR LIFEIt’s new
YesHave you tested to see if the bulbs aren't just burnt out?
Wires re all good is there a relay some where or could the head light switch cause it?
NoPlease read and sit and think about posts #7 and 19. Maybe go look at the items mentioned in posts # 7 & 19. Then think a little more.
There are no relays in the headlight circuit unless someone did some rewiring in your car. We have no idea if this is the case based on your description (or lack thereof)
Is your name Smitty by chance?
NoWires re all good is there a relay some where or could the head light switch cause it?
