abodyjoe
yea get an under car pic if ya can.
18 years on TTIs, and about 120,000 miles including 5 winters. But to be fair, the winters were hard on the topside welds on the merges. I had to repair them twice in the first 8 years or so, and the drivers side needs patching again. The head flanges never leaked or loosen off by themselves, or burned the gaskets out... on the Eddies.I replaced the first set of gaskets after about wearing them out with 10 engine swaps. I still have them and they are my back-ups. The second set are about 13/14 years old .The last cheap headers I used around 93-94 got flattened at the end of my driveway dropping off the curb onto the street....so the lasted about 15 feet of driving.
The old chrome TTIs on my scamp are over 20 years old and are still good... just ugly.
Yes but the original poster wants headers he doesn't need a recommendation to leave the stock manifolds on that's not what this is all about it's about headers on a budget?actually it was recommended to stick with the manifolds if ya read the thread.. the dougs and tti were only recommended if he just had to have headers..
I don't think these are the headmen's or the hookers that you are talking about? Like I said these are cheap Summit headers. Two things about that number five number seven obviously you don't change the spark plugs while they're hot duh. And they make these little fiberglass socks that go over spark plug boots? There in about every parts store I've ever seen. Now I did ding in the passenger side one where the torsion bar comes through. No scrape's and no fit problems. Been in and out more than a half dozen times. Always a new set of carbon gaskets and never a leak or have to retighten.yea get an under car pic if ya can.
with a good header like tti or dougs you don't need silly things like that... putting crap like that on would drive me nuts the way it looks every time i popped the hood..And they make these little fiberglass socks that go over spark plug boots? There in about every parts store I've ever seen
$400 340 logs and a nice 2.5 head pipe. Ask about Magnum log fitment, could get them for 1/4 of that. I like the wrap too. Screw the rust issues, if its a daily driver they will work fine. lots of F.A.S.T. guys killing it on logs and street tires.
kinda hard to see but that car looks to sit kinda high. sure you can crank the bars up so a car sits like a 4x4 so they never hit but i prefer mine sitting more stock, maybe a little lower then stock all the way around.. i know that oil pan hangs on the lower side but look at the damn header its even lower then the pan.. no thank you...
those cheep one should work at the track fine since its about as smooth as ya can get. but on the street the way they hang really sucks balls.. and thats speaking from my personal experience..
at $400 you can get better headers and realy at that point the remaining exhaust will be much cheaper compared towith manifolds. FAST is a way different ballgame$400 340 logs and a nice 2.5 head pipe. Ask about Magnum log fitment, could get them for 1/4 of that. I like the wrap too. Screw the rust issues, if its a daily driver they will work fine. lots of F.A.S.T. guys killing it on logs and street tires.
What is their 20% code? i cant seem to find it anymore.Doug's plain/raw headers are about $350ish with the 20% AutoZone discount, free shipping. iirc.
Tried a set of Sanderson shorties on my 75 Duster (pwr steeering) & an absolute no fit. They are built really nice w/ good craftsmanship but would not clear the steering box or steering coupling. Might fit other A bodies tho.Sanderson dd7, 550 with ceramic coating, 360 without it. They are shorties, so you don't have to worry about dragging them.
Turns out I end up with the same problem on mine, they would have fit great on manual steering but I had to do quite a bit of modification to make them fit with power steering.Tried a set of Sanderson shorties on my 75 Duster (pwr steeering) & an absolute no fit. They are built really nice w/ good craftsmanship but would not clear the steering box or steering coupling. Might fit other A bodies tho.
They can work.Tried a set of Sanderson shorties on my 75 Duster (pwr steeering) & an absolute no fit. They are built really nice w/ good craftsmanship but would not clear the steering box or steering coupling. Might fit other A bodies tho.
