PanzerschreckLeopard
Yeah, another one of these threads.... 1971 Valiant.
Well, so, one day I drove to work, and the high beam indicator never seemed to go off....just "on" and "on but slightly dimmer," even with switch off. Get there and discover the headlights don't work.
Trying to check things today, and:
Switch seems to work.
Hazards and Dome and any other lights work.
Foot dimmer switch does not work correctly (Either the Centre pin has continuity to the Red "high," or it doesn't have continuity to either outboard pin), BUT, bypassing the dimmer switch with a jumper does not solve the issue; it will still do the same behavior with the high beam indicator light, being "slightly dimmer" and then goes "on" when I jumper the centre pin to either of the others, with the lights not being on.
Finally, I remove both the headlights, and find that, with the foot switch still disconnected, both of the outboard pins have about 5 ohms to ground, and the centre pin is open.
So, what should I look at next?
