Snake
Mopar Nut
One of those is a two-groove lock, and the other is a three-groove lock... You must match them with how many grooves that you have on your valves...
That little difference in the width of the journal will not hurt it. As long as it sits in the cam bearing and is the proper diameter....
Snake, you can go to a hardware store in the fastener aisle and look for a woodruff key drawer/box. Get the 3/16" x 3/4" woodruff key...
The cam is in now and spins nicely and ya after searching i found your thread about the keys,thanks,next is to get the short block to the engine builder to degree it.
