MudFlap
Active Member
So I took the radiator outta the ole girl and took it to a radiator shop. When I got it back, I treated her to some brand new antifreeze, after I flushed the cooling system and heater core. Upon putting the radiator and antifreeze back in, the heater was nice and hot. But that was the only time. Now, it's only barely warm out the ducts. I put a 180 degree thermostat in it. I can feel the heater hoses are hot, so I know it's circulating and not plugged up. I haven't found a valve to shut off flow or anything. The Off-Heat-Defrost lever is broken, but I've reached up behind the dash and actuated both cables to the defrost position. Also, The temp lever is there and works, it actuates the cable, and I can hear the door working in the box. The blower motor works fine. Any ideas?
