HEI... here we go...
Slant 6 Engines
  1. theFightingFew
    theFightingFew Always Learning/1975 Valiant Custom/1974 Valiant FABO Gold Member
    131
    168
    Apr 9, 2020
    Philadelphia, PA
    Local Time:
    7:56 PM
    Well I finally squirrelled together the last of the components to do me up the HEI conversion... Just gotta run and get some electrical connectors and away we go.
    • Like Like x 2
    • pishta
      pishta I know I'm right....
      19,163
      8576
      Oct 13, 2004
      Tustin, CA
      Local Time:
      4:56 PM
      Good luck. Post up the details. One of the hei modules has a 7-10 degree starter assist retard on one of the extra wires.
      • Like Like x 1
      • Thanks! Thanks! x 1
      • 70aarcuda
        70aarcuda Master Hoader of SBM FABO Gold Member
        16,036
        4666
        Jan 16, 2005
        las vegas
        Local Time:
        4:56 PM
        Can you post what parts you are using as I want to upgrade the ignition on my daughter 63 valiant wagon....
        • Like Like x 1
        • Agree Agree x 1
        • RustyRatRod
          RustyRatRod Lemmie see your b00bs. FABO Gold Member
          67,826
          42148
          Jun 7, 2010
          Georgia
          Local Time:
          7:56 PM
          Do post pictures please. First I've heard of this one. I love the 63s.
          • Like Like x 1
          • Agree Agree x 1
          • theFightingFew
            131
            168
            Apr 9, 2020
            Philadelphia, PA
            Local Time:
            7:56 PM
            Ok well I was hoping to have it in the car tonight and be zip'n down some twisty country backroads... my wife always says I get a bit over ambitious... but here is the progress...
            To be clear I am pretty much following the recipe posted by @slantsixdan over here - HEI Electronic Ignition Retrofit How-To
            PARTS I AM USING: (because @70aarcuda requested )
            Heat Sink - AMZN LINK
            Bracket - AMZN LINK
            Coil - AMZN LINK
            Control Module - AMZN LINK
            Pigtail - AMZN LINK
            Heat Sink Goo - AMZN LINK
            Lightning Cable - AMZN LINK
            Electrical disconnects, wires, and some #8-32 x 1in machine bolts/nuts from the hardware store.
            • Like Like x 1
            • 70aarcuda
              16,036
              4666
              Jan 16, 2005
              las vegas
              Local Time:
              4:56 PM
              Is the distributor a stock mopar /6 unit?
            • RustyRatRod
              67,826
              42148
              Jun 7, 2010
              Georgia
              Local Time:
              7:56 PM
              What plug wires are you using?
            • theFightingFew
              131
              168
              Apr 9, 2020
              Philadelphia, PA
              Local Time:
              7:56 PM
              If i was more knowledgable I probably would have sourced different parts (maybe) but I was easily able to modify what I had with a Dremel cut-off wheel and some drilling.
              The heat sink lined up with the bracket
              The control module was out of position due to the first fin on the heat sink - see how the holes don't line up
              I removed the first fin with a Dremel cut-off wheel
              All lined up
              But the control module had some feet... so back to the Dremel and off they came
              The coil only lined up with one bolt hole so I inserted the one bolt and snugged it down then marked a new hole through the back and drilled
              Yay...
              • Like Like x 1
              • theFightingFew
                131
                168
                Apr 9, 2020
                Philadelphia, PA
                Local Time:
                7:56 PM
                Threw some heat sink goop on the sink placed the control unit on and bolted down...
                Added connectors to the pigtail and made up some wire for the distributor...
                and this is as far as I got for tonight... booooooo... tomorrow's another day...
                • Like Like x 1
                • theFightingFew
                  131
                  168
                  Apr 9, 2020
                  Philadelphia, PA
                  Local Time:
                  7:56 PM
                  Hey Rusty, I have a set of those extra fancy LiveWires I harvested from my '74 Valiant that the previous owner put on... and took these guys off the '75 that I'm doing this conversion on that I've been running since I acquired the car... I'm putting these in my original parts storage box... I like the way they look!
                • theFightingFew
                  131
                  168
                  Apr 9, 2020
                  Philadelphia, PA
                  Local Time:
                  7:56 PM
                  Yes - original unit that came with the engine/car (though I do not know if it is the original one "from" the car - I don't know how to read codes yet) - this is from when i took it out last year after acquiring the car to clean it up a bit, check the reluctor gap and drop some oil on the felt... it still seems to be functioning well
                  • theFightingFew
                    131
                    168
                    Apr 9, 2020
                    Philadelphia, PA
                    Local Time:
                    7:56 PM
                    UPDATE:
                    So I got a bit more done last night. I need to do clean up but I wanted to test it to make sure I had an understanding of what I was doing... I'm sure there may be some placebo effect going on but it feels stronger and much smoother...
                    I removed the Mopar 5 wire ECU and sealed up the connection - I'm really not sure what to do with it... I wouldn't mind going through the harness and cleaning up un-needed wires but I also feel I should leave it as a fall-back to go back to original set up if needed... any constructive thoughts are appreciated.
                    I created 10 gauge jumpers for the ballast resistor - I got this idea from a B-Bodies only post here. I thought it was a good way, again, as a fall-back.
                    I removed my Accel Super Stock coil, bracket, and I assume the cylinder-ma-bobber is some sort of noise canceller (I'm interested in knowing more if incorrect)?
                    I sealed up the coil wires and the male/female torpedo connector - Again, I'm not sure what to do with them... would love to clean up - constructive thoughts welcomed!
                    So here is the install of the coil and control module.
                    1. I ran a ground from the control module to the alternator.
                    2. I am currently picking power up from the 12v ignition switched BLUE WIRE coming off the alternator. This previously went to the electric thermostat choke pull-off on the original 1bbl Holley 1945 set up which has been replaced with a Holley 350 cfm set up with electric choke also powered by the blue lead.
                    3. I currently don't have a relay set up for the coil as I was just testing - THIS IS WHERE I COULD USE SOME ADVICE as I'm getting a bit lost at that point in the recipe linked above.
                      • If I run a 10ga. lead from battery + to a relay controlled by the BLUE LEAD would that be CORRECT? Do I even need a relay if i'm using the blue lead? (The blue lead is also feeding an aftermarket volt gauge.)
                    4. I still need a fuse. I imagine this would go on the 10ga from the battery +? (or between the blue lead/coil if no relay as above?)
                    I'm not 100% content with the location of the install but am currently limited by the length of the coil wire. I have read various opinions about coil wire length... shorted is better etc... but i'd love to move this whole thing back towards/to the firewall - Thoughts? All in all it's definitely not the sexiest package, but like everything else when working on our cars I'm proud to be going through the process of building it out myself.
                    Thanks FABO
                    • Like Like x 1
                    • Badvert65
                      Badvert65 Long Time Mopar Nut
                      343
                      121
                      Sep 21, 2014
                      Brightwood, VA
                      Local Time:
                      7:56 PM
                      You can make it "cool" looking if you use your imagination. I built this and mounted it to the right front side of the engine.
                      • Like Like x 2
                      • trapster
                        trapster Well-Known Member
                        2,649
                        249
                        Feb 19, 2009
                        Central Florida
                        Local Time:
                        7:56 PM
                        Don't forget to open up your spark plug gaps. :)
                      • theFightingFew
                        131
                        168
                        Apr 9, 2020
                        Philadelphia, PA
                        Local Time:
                        7:56 PM
                        Yes! I did that... Forgot to put that in the notes. Gapped at 45. Thanks.
                      • theFightingFew
                        131
                        168
                        Apr 9, 2020
                        Philadelphia, PA
                        Local Time:
                        7:56 PM
                        Cool man... Now that I got it all work'n you've inspired me to get a bit crafty with it!
                      • pishta
                        19,163
                        8576
                        Oct 13, 2004
                        Tustin, CA
                        Local Time:
                        4:56 PM
                        I should send you a gold Pentastar to stick on that big glaring "GM"! Nice work.
                        Here is the GM 5 pin HEI hack: "5 pin HEI module out of an '80 Oldsmobile Toronado w/ 307 or 350 engine, works just like a "regular" 4 pin HEI module, but ground the 5th pin and it will retard crank timing 5 degrees" Another states 5 pin HEI "Used on early non-efi HEI vehicles for detonation control such as 1980 Pontiac TransAm Turbo (301 olds), retards BY 10 deg when 5th pin is grounded" eg. Standard Motor Products #LX-330 (?)
                      • trapster
                        2,649
                        249
                        Feb 19, 2009
                        Central Florida
                        Local Time:
                        7:56 PM
                        would the Hei module have worked better if you flipped it over ? So the connectors are pointing toward the coil.
                      • trapster
                        2,649
                        249
                        Feb 19, 2009
                        Central Florida
                        Local Time:
                        7:56 PM
                      • theFightingFew
                        131
                        168
                        Apr 9, 2020
                        Philadelphia, PA
                        Local Time:
                        7:56 PM
                        Yes - maybe not that one specifically but... In any case I read/saw somewhere that some control modules emit different frequencies/wavelength (or some other kind of magic) so I was reluctant getting the whole package just to have to swap out the control module anyway. Since this way my first HEI install I opted to follow the recipe @slantsixdan posted over on slantsix.org with the parts he mentioned as I felt it was a safe and thoroughly researched path forward.
                        Plus, making the thing out of all the parts was fun, and though I had to do some minor modifications I enjoyed the problem-solving/building process... it gave me something to do instead of sit'n in front of the TV at night :)
                        • Like Like x 1
                        • theFightingFew
                          131
                          168
                          Apr 9, 2020
                          Philadelphia, PA
                          Local Time:
                          7:56 PM
                          "worked better" or "fit" better? Worked - no as long as wiring was correct it would be the same. Fit - no it still would have hit the fin and if i remember correctly was more misaligned due to the inside corners of the module being at a further distance from the mounting holes.
                        • slantsixdan
                          slantsixdan =..=
                          6,745
                          1935
                          Jan 7, 2007
                          Vancouver BC
                          Local Time:
                          4:56 PM
                          Can't do that—there's one particular "bottom" surface that must be in heat-greased contact with the heat sink.
                        • nitro_rat
                          nitro_rat FABO Gold Member FABO Gold Member
                          105
                          30
                          Apr 25, 2020
                          Texas
                          Local Time:
                          4:56 PM
                          Standard LX330 is the '80 Toronado application, LX331 is for the '80 turbo Trans Am with Canadian emissions (US applications used a 7 pin module). There are no details listed about the difference in retard degrees if any.
                        • pishta
                          19,163
                          8576
                          Oct 13, 2004
                          Tustin, CA
                          Local Time:
                          4:56 PM
                          ^^ the LX-330 was referencing the 307/350 Olds engine, my cut and paste put the T/A reference in between, causing 'confusion and delay' (poor form pishta!) :BangHead:
                          Update>> @nitro_rat they look to both retard 10 degrees, one lists 5 crank timing , other source listed 10 timing (probably @ cam)
                          • theFightingFew
                            131
                            168
                            Apr 9, 2020
                            Philadelphia, PA
                            Local Time:
                            7:56 PM
                            Ha! I know... Everytime I look at it I get a twinge of pain... Like when you have a small metal filing stuck in your finger you just can't seem to it dig out but you know it's there.
                            I'm definitely going to have to dress it up. And I appreciate the compliment.
