twayne24365
9s and 10s BONE STOCK?
9.59.
A GT500 need's drag radials to get in the 11's
With exception to tires, that's the story. Car appear stock. They say they are stock. That don't mean much.
If you run the numbers through any calculator you'll come out with high 10's. 3800 pounds. 662 flywheel hp.
From what I've read about them they require some small tweaks to get low 10's and 9's like boost control, launch control, tuning tweaking, tires, 2 step, etc.
What did it have ? The drive shaft will be a problem but any guy running slicks won't bother with a stock replacement you could have a local place make a strong light weight one made up.Rumor mill is saying 10.48 car had more than just race fuel. It is also on its 3rd driveshaft..
