jwsewell
Active Member
Hello, My name is John. I have been reading thru the post here and really like the forum. So I desided to introduce myself.
I have a 74 Scamp that a bought about 1 1/2 months ago for a project car.
It has a running 318 that is coming out to make room for a 413 Big block.
The 7 1/4 rear end lost the RR axle bearing on the drive home from buying the car buts thats all good, I have a A-body 8 3/4 housing and 742 Third memeber now!! :cheers:
My goal is to build a 12 Second bracket / street car for less than $3000.
So far so good. As of now I have spent $1275 and have the car, the 413, the 727, 2800 stall, 1 3/4 headers to modify, 8 3/4 housing, third member, ect.
All I really need to finish this all up is axles, driveshaft, engine mounts, Radiator, entire fuel system, throttle and trans. cables, front pully setup, manual sterring box, subframe connectors, minispool and a pair of slicks.
Here are some pics.
Here are some pics.
