340_dart_power
Try SuspensionConnection.com and if that fails, call them. Jeremy was able to arrange a dropship from Hellwig. The price was around $300.00, delivered.
First off, I have driven my car. It is night and day. The handling is better than expected.
Seondly, in regards to the Addco bar, the only bar that is any good is the 73-76 one that has the flat metal plates for the frame mounts. The 67-72 SUCKS. the frame mount is a joke. An L bracket with a vertical placement for the D-shaped bushing.....gimme a break. JUNK...JUNK .......JUNK.
The front bar should not require cutting the factory tabs off the LCA. We include the shock mount brackets for installations without factory mounts. If anyone is having problems with using factory mounting tabs, please call me at 559-734-7451 and we will get the issue resolved.
Here is the new tubular model front bar from Hellwig for my '71 Dart.
Many thanks to Dave from Hellwig who assisted in getting this part correctly ordered through Suspension Connection.
where are you in tennessee?!
I ordered one from Summit on Monday, It was not in there system, but it is now PN 55906.
One is being drop shipped from Helwig for 236.39 + shipping.
Hey 340, did you ever get a chance to measure the width of you new REAR Helwig? It looks like it might fit an early A.
The width of A bodies only changed in the front in 67', the rear axle width is the same 62-76.
Here's a shot of the rear one with degreaser suds dripping down from everything....
Just did the Hellwig(6907) rear bar install today. I had a couple questions so I called. It was very refreshing to actually talk to someone that has done the install! No waiting on hold,etc. BIG thumbs up to Hellwig for a quality piece and customer support to go with it!!!! If you're thinking of a sway bar addition or upgrade.....think Hellwig!!!
Dave,
What is the price on the 69 plymouth barracuda sway bars?
Randy
