Which has what to do with getting the right set up?And likely resellers... Of this kind of product it ain't rate..
Not quite sure what this means.And likely resellers... Of this kind of product it ain't rate..
Correct what you said about Brewers being very knowledgeable about four speeds and such, but if they sell clutches likely they don't build them or make them... They probably resell somebody else's clutch with their name on it. just like Hughes does with a lot of their products. Some good products they make, but a lot of their stuff is resale also, example cams...Not quite sure what this means.
But the best clutch for the job is a Soft-loc (adjustable sintered iron clutch) and manual clutch linkage (not hydraulic).
And mine did it on the street with street 295s as well. Which is one reason I swapped out the CFII disc.They are a very harsh clutch, I always called them parts breaker clutches, they love to eat up driveline parts.
Of course this is an old thread and I'm sure you seen mine...I am building a similar car and chose to go with the Mcleod RST and their 20 lb SFI flywheel. I have not run it yet so I cant say about performance.
I also got a Clutch Tamer but for the life of me cant see how or where you can install it in an A-Body due to the handbrake and column placement ! No pics or videos available for guidance...
For the hydraulic clutch the clutch tamer has a new product called the hit master. It's made for hydraulic clutches and has timers and all kinds of stuff like that. The price over doubles but I guess it's the cat's meow...Yes a sintered iron disc will chatter bad on the street because the hotter they get the grabber they get, when driving on the street you have to learn to just let it out do not try to slip it out. Hydraulic clutch linkage actually reacts slower then mechanical linkage, for a street car that goes to the track once in a while they work fine and are alot easier on the leg, but for best performance mechanical. Just don't expect good 60 foot times with a 2.66 first with out excessive clutch slip, and Centerforce DF don't like to be slip like that. They are a very harsh clutch, I always called them parts breaker clutches, they love to eat up driveline parts.
X’3 here. In a heavier car (E body) 2.66 first, 4.10’s and a 27 inch tire with a big street cam, single plane intake, etc... the car wasn’t to happy at the starting line.And mine did it on the street with street 295s as well. Which is one reason I swapped out the CFII disc.
Does anyone make a sintered iron full disc with a sprung hub? Seems like that would be the best of both worlds (grip, reasonable plate load, and better street manners)... closest thing I could find was a Ram 900 series (sintered plates, sprung hub).
Only 600 lbs plate load?? Is that fixed load, or centrifugal assist?
You must be able to push the clutch pedal with one finger ;)
I'm very careful with the plate load that low for just screwing off on the street because it's real easy to drive through the clutch if you're not careful.
I know guys running as high as 1500 base pressure on the street and they don't get chatter either. But that's a TON of load for the disc. You hit the car with bite and that much plate load and it will probably break parts.
So, what kind of pressure plate has that adjustment range? Is it super expensive?
What could I expect to use in my current combo, mostly street, a little strip? I'm guessing more than 500 but less than 600 ft-lb (without the nitrous). I know this sort of question gets complicated quickly, just trying to get a general idea what to upgrade to if (when?) I drive over my Centerforce ;)
