Spanishgold76
Active Member
I'm looking to hop up my 318 up a little the it already has a summit racing weiand action plus intake and 500 cfm carter recently i installed an 8 3/4 with 3.55 and a sure grip the plans for over the winter are to instal install a hughes whiplash cam and to gasket match and install 1.88 intake and 1.60 exhaust valves into 302 casting heads as to keep compression and install either a set of dougs headers or repo 340 hipo manifolds
budget is tight but I'm open to opinions
