Help with broken 66 273 Dipstick Tube?
Bossanova5
Los Angeles
The dipstick tube got damaged and broke off flush inside the block.
Any remedies for removing the portion of the tube stuck in the block?
Is the dipstick tube specific to the 273 or will a 318 fit?
Best source or way to find a replacement tube?
Thanks for the help
You could try an easy out.
Or a proper sized tap.
A pointy awl could bend the tueb in and then with needle nose twist the bent in part like a spam can opener.
Do your best to not let it drop into the oil pan
if you have the motor open, say to swap or reseal the oil pan... i'd just flip that bish over and knock the mother out from the inside with a push rod.
Oops, meant to re-post this
Use a slightly larger screw or "lag" bolt to screw into the broken tube.
Tighten until the broken tube turns, then twist and turn and pull with vice-grips.
I actually have a slide hammer and lag bolt specifically for that purpose, so I can leave the alternator in place.
Tap new one in using a 7/16 open/close wrench against the"flare".
Mr Gasket 6923: Oil Dipstick & Tube Chrysler 318-360 | JEGS
Good luck
P.S. some use a 3/8? tap to try and thread the tube, but the tube usually turns before any significant thread is made .
Cheers
